Band on Derailleur Size?
Hi,
I need a new band-on front derailleur. I am planning on replacing a knackered Microshift jobby with a 105 5700. My bike is a 20 speed Boardman CX.
The trouble is, I have no idea what band-on size I need! I measured the tube at 140mm circumference and divided by 3.14 as per GCSE maths (now mostly a distant, foggy memory) to get a figure of 44.5mm
But the 105 only comes in sizes up to 34.9mm.
I'm guessing the issue here is with my measuring/calculating.
Should I just get the biggest option? Or be looking at a different brand of derailleur?
Cheers.
S-Express
take the seatpost out and measure across the top of the seat tube - that should get you near enough...
Not if the seat tube is 34.9 it won't.
Useful guide here:
9cm seat tube circumference = 28.6mm clamp
10cm seat tube circumference = 31.8mm clamp
11cm seat tube circumference = 34.9mm clamp
OP either your maths is wrong, or you haven't measured the tube circumference correctly.
The part I quoted will work, no need to mess around measuring the wrong bit of the bike
S-Express
Your link is to a FD for either 28.6 or 31.8 dia fixing. So, if the bike requires a 34.9 FD, then it won't fit - which is the point I was making that you (still) seem to be missing..
I don't know which model year you have but currently the seatpost is 31.6 so I imagine the 34.9 will be the one but you really need to measure it.
EasyPeez
EasyPeez
get a cheap set of vernier callipers and remove the element of guesswork
Looks like a nice tool, but having got through the last 38 years without needing any (or even knowing what they were) I'm not sure how much use I would be likely to get out of them.
Ignore me if this is a daft suggestion but you have the old one, don't you? Can't you use that as a guide?
No. I binned it when I couldn't get it to work loose. Silly really.
This is the one I'm replacing, so I think @Racing roadkill is right about the one I need, but will take the seatpost out and measure the seat tube tonight to be sure.
Cheers.
