Arch
Married to Night Train
- Salford, UK
I'm going to try out some Nitto moustache bars on my tourer, and need to tape them. Will they use the same amount of tape as drops? They are 14" (36cm) from stem to end. And 23.9mm diameter.
Chuffy said:Quite a bit less than normal bars I'd say, depending how far into the middle you want to go. Just out of interest, are you running those with STIs or bar ends?
hubgearfreak said:i found them to be roughly the same, but which end to start with still puzzles me.
Profligate Jezebel!Arch said:I don't mind having tape left over, I may want to add some padding underneath, so extra would cope with that. I'll get sheap to start with, then if they work out, find something nice. I fancy leather to match my Brooks saddle.
Thanks for the help all!
Soltydog said:I have some 'dusky orange' bar tape that needs a new home if it's any good to you Could bring it along on the 25th
Arch said:How 'dusky' is it? If I don't get proper leather tape, I'd like something that tones with the honey saddle....
Dayvo said:Just for you, although I don't think it matters if you start from the middle.
Chuffy said:Profligate Jezebel!
I can heartily recommend the Cinelli Gel. It's easy to re-wrap if you make mistakes as it has a 'tacky' strip rather than normal adhesive.
Crankarm said:+1 for Cinelli Gel bar tape. It really is the business very comfortable and easy to fit. It's cheaper at CRC though £12.99 rather than £15+ from Wiggle.
http://www.chainreactioncycles.com/Models.aspx?ModelID=25854
jimboalee said:.
PS Handlebar tape is called 'Ribbon'.
