Bean to cup machine questions.
Profpointy
I bought a cafe quality grinder secondhand and use an Italian type stove top pot to make the coffee. The coffee bore enthusiasts on t'internet all said to spend a good wodge of money on the grinder, and having done so, I concur that freshly ground coffee done in a good grinder is a lot nicer than buying pre-ground.
I also think not having all your eggs in one basket is a good move. With a separate grinder I do have the option of using different brewing methods: mokka pot, French press, grinding coffee to take away on holiday, and buying an espresso machine proper in the future. And if I do buy an espresso machine if grinder or machine goes wrong I don't have to replace the whole thing
Anyhow, that's what I did and would do again. Buy a 2nd hand Mazzer or whatever make grinder off ebay, ideally off a vendor who refurbs them, then use whatever method you want to make the coffee
Dorset Boy
We have a Sage Oracle Jet - very expensive but very good. Maybe a bit overkill for what the OP wants.
T4tomo
Given we've moved off answering the OP into posting picture of our own equipment and espousing wisdom....
I would say always use whole beans and grind just before you brew, rather than buying ground coffee.
You can get a hand grinder from about £30. Granted its isn't as good as a flashy £800 Mazzer, but bang for buck wise pretty decent and perfectly adequate for domestic one or two cups at a time brewing.
Similarly a mokka pot or aeropress or a humble cafetiere (although I find them a pain in the butt to wash) does a very decent brewing job, albeit not quite as good as an espresso machine, but at a fraction of the price.
Binky
The OP asked for thoughts on coffee machines, not how how else we answer if not giving own experiences and what we do and have?
T4tomo
You're over thinking a throwaway comment, which may be the reason for your addled sentence construction.^_^
Electric_Andy
Heavy Metal Fan
Plymouth
At the end of the day (when all's said and done), it's all about personal preference isn't it? With our £20 jug machine, and the cheapest ground coffee I can find (£2.60 for 400g at Lidl), we are very impressed with the flavour we achieve. With heated and gently whisked milk, we can get a brew as good as Costa for under 40p a cup. And yes, I've had a few flat whites with oat milk from Costa, and other outlets, so I reckon I have a fairly good base for comparison. That said, we found a vegan cafe in town at the weekend and their coffee was awful. It wasn't that strong, but tasted of molasses. I don't doubt it was good quality, but sometimes better quality does not mean it's going to sit with everyone's tastes
Bonefish Blues
Banging donk
52 Festive Road
The best coffee is the one you like.
Binky
Hmm seeing as only two of us actually posted a picture then I'd say it was more of a pointed comment than throwaway.
But again, not sure what you expect people to say towards a question asking for thoughts on coffee machines?
Surely better to give specific, first hand opinions than some vague musings.
T4tomo
I most definitely wasn't having a pop at anyone personally. it was more an irreverent / lighthearted comment on the usual cycle chat (and most forums tbf) thread drift and then using it as an excuse to go well left of the original topic field myself.
si_c
Wirral
Depends. If you open a bag and use it within a week, getting coffee ground from a roasters is a better bet - you'll get a fantastic grind that'll outperform a cheap grinder even after a week.
The type of grinder you get for £30 will be very likely be low quality and have a mechanism that will pulverise rather than grind.
An aeropress, mokka pot or cafetiere will brew an excellent cup of coffee, better than most bean to cup espresso machines, but you need a good bean, ground well and to understand the brew method.
A bean to cup coffee machine is better than a pod based brewing system but that's a low bar to clear as for the most part they're pretty awful.
