carpiste
- Manchester
To be honest I can`t imagine anything worse than a beer anytime during or prior to a ride. I get maybe a beer or two after the event but not for me I`m afraid. Tea at a cafe is worth stopping for though
ah, I thought perhaps you meant something more exotic.Salt ((ed) peanuts) diluted with 96% water (beer).
A danger to yourself and others after a single pint at home after a ride? I'd definitely stay away from the mighty hop Paul.Beer and cycling? Not for me, it would be too dangerous. I've occasionally had a pint, just one, during or after a ride. The effect is always the same, slightly inebriated and a danger to myself and others.
My theory, which I can't prove, is as I'm dehydrated and probably hungry the effect of alcohol is increased. Beer, bike and me isn't a good combination.
No, no. I mean stopping for a pint after the ride and then having a 6 mile ride home. After 70-80 miles a pint has a very quick effect on me.A danger to yourself and others after a single pint at home after a ride? I'd definitely stay away from the mighty hop Paul.
Slightly inebriated? Have you considered a complaint to the brewers?
I suggest my other favourite evening tipple as a safer alternative for all concerned.
Used to be available at Sainsbury's - now you have to go down the big river for it.
Hopefully the bike was still by your side?we had a beer or two which resulted with me waking up in a field several hours later using a cowpat as a pillow
I think some electrolyte loss is common isn't it, so I imagine a replacement of salts is important along with your choice of isotonic beverage.
Green Tea, I enjoy green tea, but for some reason it has me peeing frequently, more so than coffee or beer 🤔Doesn't matter whether you decide to "buy" it or not, alcohol is a diuretic and does result in a deficit of water. It does this by suppressing water reabsorption in the kidneys. How significant this is depends on the quantities involved.
The thing to realise is that alcohol is not digested in the same way as "normal food", a search for "alcohol digestion process" may be informative, as may be https://pubs.niaaa.nih.gov/publications/aa72/aa72.htm One of the side effects of breaking down alcohol is that some of the water within the body that was part of these reactions is now too impure to recirculate so it has be disposed of......I also don't buy the "diuretic" line - I mean a pint of liquid is a pint of liquid - it's not going to produce a deficit of liquid in your body. .....
Sounds like fun, until you do the sums, a typical person can process 1 UK unit of alcohol an hour, apparently body size doesn't matter that much but there are some suggestions that for women it is a little less. One pint of 1.8% beer is one unit, a while back you could occasionally see 2.8% beer as the duty is half that of normal strength beer, but I rarely see anything less that 3.6% so I suspect that you can see the problem.There was the “ 100 Club “ I heard about back in the 80’s. The challenge was to run 100 miles and consume 100 pints in 100 consecutive hours........
Yep. Well-established science.Doesn't matter whether you decide to "buy" it or not, alcohol is a diuretic and does result in a deficit of water. It does this by suppressing water reabsorption in the kidneys. How significant this is depends on the quantities involved.
so you drink a pint of liquid - get no bodily benefit from that pint of liquid and lose some of the benefit of liquid you have otherwise consumed?Doesn't matter whether you decide to "buy" it or not, alcohol is a diuretic and does result in a deficit of water. It does this by suppressing water reabsorption in the kidneys. How significant this is depends on the quantities involved.
