The plus side of the ones that convert to mini track pumps (like the Morph) is that you are pressing towards the ground rather than holding the pump with the other hand.
True, but with an important caveat: with some tubes (Continental, I'm looking at you), the valve cores can unscrew as you undo the hose. Said valve core is then ejected at 100psi, never to be seen again. There is a reason I know this...
