T4tomo
No, my partner is a cyclist too.You must be single.
Hi, what does the GT85 do... prevent rust?Mine all sit in an unheated garage, they've never come to any harm. I think the oldest one in there (my pub bike) has been stored in that manner for 9 years now, hardly ever gets cleaned or maintained, and it's not suffered any.
If I rode my best bike on a very wet and mucky day, it would get a quick spray of GT85 and then into the garage, it'll get a wash and lube once it's dry outside.
Hi, why is the outdoor shed considered "worst environment" ?The title has the options. Here's the issues:
Any suggestions about which way to go? Thanks.
- Outdoor shed -- least obtrusive, worst environment.
- Unheated attached garage -- better environment since temperature is moderated, but a bit in the way (even low-ceiling or wall mounted).
- Basement -- most moderate temperature by far, but somewhat humid first month or two, and most in the way.
Indeed. It may be that the OPs shed is damper than Pamela Anderson's swinsuit, but as regards sheds in general it is auch a sweeping statement as to be meaningless.Hi, why is the outdoor shed considered "worst environment" ?
yes, by repelling moistureHi, what does the GT85 do... prevent rust?
That's what I've always understood, that it (and similar sprays for that matter, MO94, WD40 ) help displace water and mitigate corrosion... it might be debatable, but it seems to help.Hi, what does the GT85 do... prevent rust?
From their site I saw:That's what I've always understood, that it (and similar sprays for that matter, MO94, WD40 ) help displace water and mitigate corrosion... it might be debatable, but it seems to help.
Ok looks like we've answered the shed thing now.... so back to Pamela...Indeed. It may be that the OPs shed is damper than Pamela Anderson's swinsuit, but as regards sheds in general it is auch a sweeping statement as to be meaningless.
Yeah it's good, spray it on all over (apologies to 'Enry). I've got Muc-Off's MO94 at the moment just because it was on a cheap offer when I bought it (it's dearer than GT85 normally), but they do the same thing. I used it before anyway, but then I realised that you could spray it straight on directly after a rainy ride and it does keep any metal parts protected. It's a bit lazy really, but it's better than leaving a wet chain.From their site I saw:
GT85 is ideal for cleaning and lubricating bike chains, frames, derailleurs, cables, levers, gears and more.
Might give that a shot.
