rh100
It appears that my brake lines have frozen this morning, the left handle won't budge, the right one did and now the front brake is stuck on.
I washed the bike yesterday and gave it a good soaking, I'm guessing that water has gone into the brake cable sleeving and frozen overnight in the shed, the cables are exposed in parts of the frame and then sleeved on the bendy bits.
So, will the brakes and gears be ok once it thaws out? is the ice likely to have done any damage?
I had also put a bit of bicycle oil onto the cables at the entry to the sleeves, I can't see this having caused any problems.
I'm glad I check my brakes before moving off now though, would hate to have been halfway down the road before finding out.
PS. I didn't do the obvious and use hot water as I didn't want to have that freeze up later on and be stuck at work with it.
