theboxers
TheBoxers on Cycle Sim sw
- OTC (on the couch)
59.28
Another pro special
but still blooming hard work
Another pro special
Heart rate was the same, but cadence was down and power was about 70 odd watts better. It sort of spoils it because you get a result you don't really deserveGreat Improvement there, even if you have been visited by the BKool fairy.
League spreadsheet all updated with times so far
. Power on the vectors was 190 watts or so for the same
, more like what I can do and about the previous runs level
.does it let you pair the pm to sort of over ride the pro ? forgive me as i am not techy at all but i am sure that when i used the pro in zwift i could pair the power hub so it over rode pro - still a bloody good work out though aint itHeart rate was the same, but cadence was down and power was about 70 odd watts better. It sort of spoils it because you get a result you don't really deserve. Power on the vectors was 190 watts or so for the same
I believe it used to, but for some reason BKool removed the facility to record watts from a PM and use the trainer to set the resistance some time agodoes it let you pair the pm to sort of over ride the pro ? forgive me as i am not techy at all but i am sure that when i used the pro in zwift i could pair the power hub so it over rode pro - still a bloody good work out though aint it
they wouldnt have done that so you had to buy their new machine by any chance ?I believe it used to, but for some reason BKool removed the facility to record watts from a PM and use the trainer to set the resistance some time ago![]()
@ibooij We so need the Lacets du Montvernier with the col du Chaussy 13.8Km, 1000m ascent, average gradient 7.5% with max gradient 12%
Spectacular ascent a hairpin every 150m on the Lacets!
I have tried it, I think, and you get the power meter readings used instead of the trainer readings (but that may have been with the classic ICR).does it let you pair the pm to sort of over ride the pro ? forgive me as i am not techy at all but i am sure that when i used the pro in zwift i could pair the power hub so it over rode pro - still a bloody good work out though aint it
I have tried the power off, wait 10 seconds, power on and it made no differenceTB have you tried turning the pro on then off and back on again once within BRVR? That might help as it does in Zwift.
Otherwise, get on the Kickr.
@Aleman looks like you've voluteered for a real life road tripThat would be spectacular indeed. I don't think we'll be able to do that the coming summer unfortunately..
Until you complete it ...How long is this round open?
Which may be James Canyon, or it may be Flagstaff
