Racing roadkill
That's right. At least the solid tyres have been tested properly by TUV.So solid wheel barrow tyres are ok on a road bike......but not disc brakes hmmmmmm
Here's a good indepth review of the tyres from @Andrew_Culture
I've had Tannus solids on one of my Hybrids for a while now. Today I fitted my ( smaller ) purchase from the bike show.
P*nct*re fairy, it was nice knowing you.
I did lose a bit of thumbnail fitting them, but I reckon that's a price worth paying. I've just test ridden a short route. All's goodI got a 'show special' price on them, so the cost was actually quite reasonable as well.
He said they are heavy going...He's dropped five stone though
Some employers are nobbers. Especially the ones that frown at a cyclist who fixed a punctured tyre but allow motorists pathetic excuses like "I had a flat tyre", "I was stuck in a traffic jam" and "it was icy".If I am late for work occassionally the world keeps turning but I do appreciate some employers are less understanding than mine.
Not a roadside job, but I have perfected the technique. You feed the tyre on to the rim for about 12 inches, then click the pins in on that section. Then you don your cleated cycle shoes, place the tyre covered bit of the rim on a soft surface, stand with your cleats trapping the rim down. Then get the heavy duty tool ( supplied with the tyres) put it under the tyre ( between the rim and tyre, then heave the rest of the tyre up and over the rim and drop it into place. It's like the most severe resistance band work out you'll ever do, but it saves a lot of messing around. Then you just squeeze the tyre down into its fixed position and use a small pair of needle noses pliers to click the pins under the clincher hooks through the inspection holes, one by one. It's actually not that hard, but you do need the shoulder strength of a sliver back Gorilla, if you want to get the tyre on in one heave.Interesting. I'd imagined they would just be a little smaller than the rim and you'd give them a big heave to get them on and tension would keep them in place. It's obviously a bit more complex than that to secure them, and looks like quite a bit of work to fit:
Definitely not a roadside tyre change job ...![]()
I've just done the first 8 mile commute, using deliberately knackered roads with loads of sharp debris at the side, I got the bike up to reasonable speed and didn't have to slow down for the corners like I thought I would, they don't squirm under hard braking either, which is reassuring.Be interested in how you get on with these. Just had 3rd visit in as many weeks from the fairy on the commute home which is starting to get quite annoying
You and a thousand others. It's odd they only do 23 and 28, in the road bike design.Wish they had 700x25.
28s would be great. You could run them at slightly lower pressure then.You and a thousand others. It's odd they only do 23 and 28, in the road bike design.
