Camping - Your hint's and tips.
oxoman
The correct way is to go lightweight and carry everything on the bike and camp en-route. Currently have everything ready to go except bike fitness. 😖 Anybody fancy trying it look up dirt dash on YouTube and some guy called Markus Stitz.
oxoman
2.5kw is quite a big load assuming you used both rings at the same time. I know my mate uses one when camping and caravaning but most sites limit you to 16amp max. Try and find a lower wattage one.
raleighnut
Looking to get an EHU for my next trip, to make it worthwhile (its for eBikes initially) I'm looking to get a powered cooler and cooker.
The cooker am I missing a trick or can I just buy something like this Lewis's Hotplate Double 2500W - White. Its £15 compare to over £100 for some camping specific solutions. Its a UK plug and from a trusted retailer so I assume it'd be ok?
Sooner have a gas stove, i've got an old 'Epigas' one (takes Colman cylinders with a screw top) cooker is on a pipe with the control on the top of the bottle so no burning fingers if something boils over
figbat
Former slippery scientist
See I knew there was something I wouldn't be thinking. I've found single/double stoves now designed for camping and less than 1500w for upto 2 rings. Also more reasonably priced at £20-35 rather than the first few I saw.
Double stove MKT-200 UK £34
MESTIC Single stove MKT-120 UK £20
I have several gas stoves, but if I'm paying for the EHU for the bikes I figured I may as well look at some other things. Not looking to go overboard though.
Is that good or bad relative to what I initially posted? I checked back on the site and their info just says "EHU" with no mention of restrictions.
Some sites are 16A, some only 10A. We used a EHU for camping and was a really good addition - electric coolbox, tent lighting, phone charging etc. When we upgraded to a caravan we always went to sites with EHU and rarely used any gas.
Solar Upgrade
Just upgraded my solar setup on the cheap (ish). Found a new, matching 100w Anker solar panel to go along with my existing one. We've managed off grid, with some careful power management, for 5 days - our main power user is the electric cool box. The 100w panel will get upto around 80-85w in cool clear weather (April/May). This recent hot weather, and additional haze, this has reduced the panel to 60-65w (they don't like heat). So, given an identical panel is about £250 RRP, I found one for £130. Only down side, is it didn't come with cables - which the seller has given a partial refund having admitted it didn't have any but their description said it did (new open box from a retailer). I've picked the same as panel as the output voltages can vary per panel from 12v upto 24v, and when combining you'll only get the lower voltage/amps. Checked the Anker panels and they are over 24v and 4amps, many others are 12v or 18v - they can be mixed, but the power station will adjust the power, so you won't be getting the best efficiency.
At present, on a good day, the panel gives enough to run the coolbox and charge the power station although getting into the evening solar drops off. With two panels it should give me more power to get the power bank full, before the evening arrives, and also give me double the power on cloudy days.
Plus side is the original panel came with a splitter so just needed a new cable from the panel to the splitter. Stuck with parallel as I had the splitter. Just have to bear in mind voltage limits for serial connections, and amps for parallel. You can connect more panels, either serial or parallel so you keep them under both limits. Three panels together would need two panels in serial then connected to the third in parallel to be within the power station's limits, which is a bit of a faff setting up each camp.
We're two seasons in now with the power station and it's been great, especially when off grid for a number of days and you have a fridge full of food, wine and beer. We've only had hookup at one site this year as it was a camper/caravan site and you had to take it.
Some sites are charging quite a premium for hookup - some £8 a night, which given that commercial KWh charges are expensive - more than double domestic 25p/Kwh, it is understandable when you see what some people bring. I know one site that charges per KWh if on hookup and they have had 'complaints' about the charge - the owner has pointed out that their fan heater, electric BBQ etc all use a lot of power. That's when £5-8 extra a night is cheap for the camper, but expensive for the site when you see some folk's set ups.
Two more camps minimum this year, one with/without EHU in Scotland - later in the holiday it will be without. Then another late September without.
Make certain you can put the tent up before you leave home.
And that all the poles are still in a fit state to use.
And make sure you know the best way to put it up quickly when it’s raining. It’s a different ball game!
Oh yes. We have a rectangular bell tent with a zip in floor. Last year we were touring so left the ground sheet zipped in (made it heavy and bulky), but on arriving at a camp site in Tenby, it was blowing a gale and chucking it down. We got pitched in 20 minutes.
raleighnut
Which is the reason why a flysheet first tent is an obvious choice - ! :okay:
my favourite tent is a Litchfield Viper 2, approx 2 minutes to get the flysheet up then the inner hangs on 2 hooks
20 minutes, I'd have the tent up and a cuppa brewed
