Cyclopathic
- Leicester.
There has to be a problem here that I haven't considered or else why did they invent the quill to ahead handlebar stem converter?
So you can use oversized bars and a modern stem combo on an older style bike AFAIK. I used to use one when I converted my fixed from track to road use,why did they invent the quill to ahead handlebar stem converter?
I knew that it was possible to use a converter to be able to fit a modern stem and bars but wanted to know if it was possible to fit the ahead headset on to a frame with a headtube designed for the quill so that the converter wasn't necessary. Sorry, I should have been clearer in my op.The converter is needed because with a threaded set of forks, there is no tube above the head tube to connect the stem to. Quill stems attach to the forks inside the head tube.
All the converter is, is a straight post with a securing wedge at the bottom, allowing you to have somewhere to attach your clamp to. I have two bikes like that and they work absolutely fine.
I really prefer the look of the quill system which is what has stopped me converting sooner. I don't hate the look of the ahead but do think it is less refined looking. However the mechanical advantages are what makes it really attractive, as well as the versitility and ease of use. Knowing that I will never again have to struggle and grind and scrape and pry to get handle bars on is sweet.You can buy a converter 1" to 1.1/8" which will take an ahead stem. Very easy job. I did this on my Reynolds 351 frame and I'm so glad I did it. I never liked the look of quill stems.
Thanks for the lookie.Blimey, I can't believe I hunted so far for info like this and now it's popped up twice in one day!
Lookie...
+1The downside of the ahead system as I see it is that although it is better in many ways i just don't think it has the elegance of the quill system.
And what is more...you'll have carbon forks.I'm still a little undecided, and financially it will be less expensive for me to get some black thread less carbon forks because I already have everything else I need. Also getting some black thread less forks would mean both my bikes match!
If I do go carbon then I'll keep the original forks for a possible future 'upgrade'.
