Odd one this, bear with me...
We have two of these Carerra CityCross ebikes; OH's is 2 years old and works fine, mine is 6 months old and doesn't. Both were bought second hand quite recently.
On OH's bike on full assist (mode 3) the motor propels it smoothly to about 15.5mph then drops out, as expected. Once the speed drops to about 14.9 it cuts in again and increases the speed smoothly back to 15.5 or so, exactly as expected and how you'd want it to work.
On mine it reaches 15.5 / 15.6 in the same smooth way, but then as the assist drops out the speed drops steadily all the way back to around 13.3 / 13.4 before the assist kicks back in. It actually takes quite a while for that drop to happen - pedalling is the obvious answer but there's a real sense of fighting against the motor to get the speed back up. If it's allowed to drop to 13.n the assist softly kicks in and pushes it back to 15.5 +/- in the usual way.
I've recreated this consistently (we have a closed road just round the corner) using the Garmin off my road bike and pedalling slowly in a low gear to keep the assist on, and it never changes - hit 15.n, drop steadily to 13.n then back to 15.n. It makes it almost unrideable with the speed dropping that slowly and therefore the assist MIA for that time. Compare and contrast with OH's bike which momentarily and unnoticeably loses assist at 15.5 / 6 before gracefully returning at just below 15mph
I've cleaned the sensor on the bottom bracket but tbh it's so consistent that it can't reasonably be that. My hunch is that it's a s/w glitch that fails to trigger the assist at the intended speed (14.9) and instead lets it fall all the way to 13.3 before kicking it back in.
Anyone else seen this? Any suggestions?
Thanks.
Thanks.
