cassette
dan_bo
How much does it cost to Oldham?
shimano of campag?
have you undone it?
ianrauk
Tattooed Beat Messiah
Rides Ti2
Give it half hour, spray in some more, another half hour then try.. but if the lockring is really stuck then leave for a good few hours.
MadoneRider1991
MadoneRider1991
Dorset
ok thanks :sad:
andrew_s
Gloucester
Is your cassette a freewheel?
If you need a chain whip to hold the sprockets still when turning the remover in the undo direction, it's a cassette; if not it's a freewheel.
If it's a freewheel it will take a serious amount of grunt to get off, involving a big bench vice or a 2ft long spanner.
arallsopp
Post of The Year 2009 winner
Bromley, Kent
..and don't forget to try tightening it a little, before undoing it. Sometimes this can help (if only to assure you that you're going the right way).
MadoneRider1991
MadoneRider1991
Dorset
i have been a bike mechanic for the past 2 years, i know what to do the locking ring is stuck and i just wanted to know if anyone had and tips on how to loosen it ;)
PpPete
Chandler's Ford
I use a small child in situations like this.....
I hold the wheel (fitted with fully inflated tyre so as provide friction on ground), and the business end of the tool in the other hand to make nothing slips. I put a scaffold pole over the end of the wrench. Child on other end of scaffold pole.
Never fails - and gives child a real thrill that they can do something that Dad can't manage.
Works on freewheels, stuck pedals, BB shells, just about everything.
