Hi
I was on here a few weeks ago about changing my grip shifter gears to a trigger unit with brakes
I started the upgrade today.
I got the old gears off, I removed the old grips. I had to run on new brake cables as the old ones were freyed. This was ok as got the connected to new brake gear shifters.
I got the back gear new cable connected and working but having issues with the front derailleur.
I'm unsure if I'm doing it right but so far I can only gears to switch on the lower and middle front gears. The grip shift was also having probs when I got the bike going into the high gear so I think it could be the derailleur or just that it was not set up right in the first place
So I'm hoping for some advice. I've added some photos of the unit to this thread. It looks a basic unit but it can never go to the large gear. When I tried adding the new cable the derailleur presses itself back in towards the bike. When I push it out then tighten the cable the best I can get is two gears working.
I'm prob doing it wrong so I wanted to ask for some advice. if I am changing the cable on the front what steps should I follow? Should I start with the derailleur on the smallest gear and the shifter on gear 3? Should I remove the chain?
Sorry I'm just starting out with bikes and am learning as I go. So any input would be great
Thanks
Thanks
