Changing from 8 to 9 speed
Jimmy Doug
If you know what's good for you ...
Hi
Well, it's looking like I need to change my rear derailleur. Currently, I have an 8 speed with Shimano sti shifters - but looking in Wiggle's extensive catalogue, I see that there are very few 8 speed derailleurs these days; most seem to be 9 or 10-speed. So, as I've already had to spend a fortune on parts recently, is it possible to buy a 9-speed derailleur and fit it on my current configuration (ie, 8-speed cassette with 8-speed sti shifter)? I suppose it should be possible, but what about the difference in chain thickness? Also, just how reliable are 9-speeds? I read somewhere that a 9-speed chain isn't as strong as an 8-speed one; this for me is an important consideration, because I do a lot of touring in the summer, and I don't want to end up with a broken chain in the middle of nowhere.
Cheers for your help
MattHB
Proud Daddy
I have a 10 speed chain and dream of producing enough power to break it. It ain't going to happen unless you do zero maintenance and wear it out way past its tolerances in which case it's your own fault
Moodyman
Dérailleur speeds are misleading. Speeds are dictated by the shifter pull, the derailleur just does what the shifter tells it. So, a 9 speed derailleur will work with your current 8 speed set up. If you want to change everything over to 9 speed then gonna be expensive as need to change shifters, cassette and chain.
Peteaud
South Somerset
Hi
Any deraileir will fit exept the newer 10 speed ones.
so for you a mountain bike rear mech, i.e deore will fit.
Peteaud
South Somerset
Ignore the chain, 8 speed cassette and 8 speed chain you already have.
You need a rear mech and if it was me i would get a new cable inner at the same time as its less hassle.
Jimmy Doug
Jimmy Doug
This is the one I already have. Reckon if I'm going to change, I might as well upgrade to something a little better: an XT or Deore, for example.
So, if I understand you all correctly, I just buy a 9-speed derailleur and use it with my current 8-speed chain - then, when the time comes, change chain, cassette, shifters and chain-ring at the same time? As it happens, the shifters and chain-rings do need to be changed, but it's not urgent.
Peteaud
South Somerset
Yes.
But, the main difference between Deore, XT, XTR is marketing imho.
Deore is good enough for most but there is nothing wrong with Acera. Its a few grams heavier and not as flash but does the same thing, so i would go for that, save your money and then upgrade later.
If you do go for Deore, then Merlin have them for a good price.
http://www.merlincycles.com/bike-sh...mtb/shimano-deore-m591-9-speed-rear-mech.html
Even says 8 & 9 speed on the spec.
Peteaud
South Somerset
For what its worth
The shifters and cassette must be the same, i.e 8 speed, 9 speed etc.
The chain is to suit above
The rear mech only does what the shifter says in terms of pull of cable to movement.
P.H
That's interesting. Is there a difference between these two Deores, apart from the price and the colour? The one in Pete's link looks longer, or maybe that's just the photo?
In practice, there's probably no difference. Deore LX is Shimano's touring/trekking groupset and Deore is aimed at MTB. The list price for LX is slightly more than for Deore. They are both designed to use the same cassettes, both should give years of trouble free use, if it were me I'd choose the colour that best suited the bike, or the cheapest.
