One problem, London is now further North.Right this will stop the Scots complaining about it being dark.My solution once and for all.I now need a plan to turn it around. View attachment 84137
See they've moved Alaska to somewhere warmer!It is almost 6 a.m. where I am, but it is 7 a.m. in Indiana, except the Northeastern and Southeastern Counties, where it is also 6 a.m. Part of the Upper Peninsula of Michigan(Da Yoop, according Mrs. GA) is on our time, but once you get out into the part not next to Wisconsin, it is an hour later. As you can see, some bits of Arizona do not observe Daylight Savings Time, and others do.
I've never been to Mexicanadaska: what's it like?It is almost 6 a.m. where I am, but it is 7 a.m. in Indiana, except the Northeastern and Southeastern Counties, where it is also 6 a.m. Part of the Upper Peninsula of Michigan(Da Yoop, according Mrs. GA) is on our time, but once you get out into the part not next to Wisconsin, it is an hour later. As you can see, some bits of Arizona do not observe Daylight Savings Time, and others do.
Deep snowfall in one part, near drought conditions in the other. And they won't share!I've never been to Mexicanadaska: what's it like?
If its a vauxhall then the clock probably stopped working for 23 hoursThe clock in my Vauxhall hatchback changed itself.
It's not connected to the outside world as far as I know.
Presumably, it's programmed to change on the various dates which are probably set for years to come.
Even so, I was quite impressed.
You appear to have moved the clocks floorwards by mistake.I have just moved the clocks forward.
Some of them fell on the floor.
I had a Vauxhall Chevette for my sins, when I was many, many, many years younger than I am today. The best thing I can say about it was that the clock was correct twice a day.The clock in my Vauxhall hatchback changed itself.
Sorted. Scots closer to Vikingland, London closer to Europe. RoI might be annoyed to find they're all Northern now.One problem, London is now further North.
Stay away from the salmon enchiladas.I've never been to Mexicanadaska: what's it like?
That's good as we can now keep all the money that goes to the north . Means Cornwall is further east, which then leads to the scots claiming west is best. Which in that case is patently bolloxOne problem, London is now further North.
