Nibor
Bewildered
- Accrington
Sugru?
Why not talk to your local heel bar man? The 1cm2 area of a stiletto exerts a huge pressure and carries a lot of weight especially while walking so a DIY bodge is risking a wardrobe malfunction or a sprained ankle.
But yes, stilettos are a powerful thing. I used to have a Spanish agent who wore them and walking around town with her I couldn't help noticing the attention they attracted, mostly from men.
Sugru?
I've used Sugru in a few applications and it's quite easy to remove and found it cleans up pretty easily. I used it to increase the size of the brifter gear paddles to give a bit more contact area when using gloves. Found that it was easy to remove and clean up with a bit of white spirit.I'm thinking in that direction although I'm not sure how I'd get it iff the heels after I've made the mould...
I've thought of doing that, but was unsure if it'd work ... brill, I'll give it a try! Thanks!!!!I've used Sugru in a few applications and it's quite easy to remove and found it cleans up pretty easily. I used it to increase the size of the brifter gear paddles to give a bit more contact area when using gloves. Found that it was easy to remove and clean up with a bit of white spirit.
WHAT! @Fnaar making a technical bike related comment! What is the world coming to?I've thought of doing that, but was unsure if it'd work ... brill, I'll give it a try! Thanks!!!!
An extension to my paddle ... what's not to like?WHAT! @Fnaar making a technical bike related comment! What is the world coming to?
At least it's reversibleI've thought of doing that, but was unsure if it'd work ... brill, I'll give it a try! Thanks!!!!
