Cab said:Oh, go put some poor sap on you-tube, brain boy![]()
I would but the bike's out of commission until next week.
I suppose I could wear the helmet camera whilst driving the car......
Should've used Cab excuse about not being able to fit your bike in your rucksack, so you didn't bother to use it.magnatom said:I would but the bike's out of commission until next week.![]()
Maz said:Should've used Cab excuse about not being able to fit your bike in your rucksack, so you didn't bother to use it.
mrben said:Having said that, I use ASLs a fair bit, but it depends on the situation, and, ultimately, this is the solution - allow people to use common sense wrt cycle facilities on the road.
Tynan said:people starting in front of an empty ASL is no part of my argument
I think the safest place to start from a set of lights is the front, that's common sense and vouched for by the appearance of ASLs, so that's where I'll start unless it obviously impractical to do so
mrben said:ASLs are a tricky one, partly because they are usually paired with a short bicycle lane on the left hand side, which encourages people to filter up the left hand side, and then pull across. If you're turning right, or if you're going straight on but the left hand lane is for turning left only, you could be in an awkward position if the lights change before you hit the ASL. This could probably be solved by an additional cycle lane between each of the lanes, but that has a whole load of problems of it's own.
Starting from behind a car does mean that the car behind you doesn't feel like he could just zoom off into the distance if you weren't there.....
"magnatom" said:I hadn't read this before I typed. It seems we agree on this. Where do you cycle in Glasgow MrBen?
) and a big laptop rucksack on my back (getting my excuses in early)
cupoftea said:So if they highway code was changed so that cylist had to use cycle lanes would you?
mrben said:From Whiteinch into Central Station. Dumbarton Road through into Finnieston, then cut down under the Expressway to Lancefield Quay and then pop up onto Argyle Street just before the station. Way home is basically the same, except I cycle along Argyle Street as far as the Kingston Bridge before turning down to the river.
Morning run is between 7-7.30am, evening from 5.40pm to 6.10pm. Usually takes me about 20-25 minutes on a borrowed (too small) Raleigh mountain bike with front shocks and knobbly tyres (weighs a tonne) and a big laptop rucksack on my back (getting my excuses in early)
Coming in there's virtually no traffic - worst bit is getting into the right hand lane at the split by Kelvingrove Art Gallery. Coming home the junction at the squinty bridge is a PITA for the same reason - timing the move into the right hand lane.
. Have a look at my videos (see my signature) you will recognise some of the sites!
If when I get there, I have to advance my normal position, for the reasons given earlier, I will, to the benefit of every party involved
I really don't see those as in any way contentious positions to take
people jumping red lights and crossing the junction are a danger to others and themselves, it's a serious road offence imho and the first thing regular people say to me when I mention I cycle to work
people starting a few feet over a stop line for good reason is no offence worth mentioning, the two things are incomparable, the only reasons they ever come up is people trying to muddy the water on rlj
I'm never happy with starting anywhere other than the front, I start in traffic when I have to but it relies on some common sense from surrounding vehicles in the second of starting to move, primary is not an option when filtering in very heavy slow moving traffic
Take your ultra conservative line by all means cab but don't try to enforce it on others who might be riding in very different circumstances
I have no idea where 'virtue' came from, not me
