Damn,another left on by mistake electrical appliance
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
I would be cheesed off after two hours
Accy cyclist
Accy cyclist
A smart meter is an electronic device that records consumption of electric energy in intervals of an hour or less and communicates that information at least daily back to the utility for monitoring and billing
That sounds like something they'd install for "bad paying" customers. They're watching our every move i tell you!:unsure:
How's a smart meter going to read his posts?
Because it's smart?
Sixmile
N Ireland
Was it one of the sandwich toasters that require a little butter on the outside of the bread and then crimps the sandwich into luxurious triangle shapes, occasionally dripping a little grease down the back of the electrics or one of these flat plate ones where the cheese just goes everywhere as each slice never meets the other at any point?
jayonabike
Powered by caffeine & whisky
Hertfordshire
I can’t be arsed to read 5 pages about a sandwich toaster. There’s some bloke outside painting a wall, think I’ll watch that dry instead.
Andrew_P
In between here and there
I am off to Argos for a sandwich toaster been resisting it ever since this post cropped up, can't wait cheese, onion with some ketchup. Genuinely been salivating over this for 24 hours its bound to disappoint bit like buying your own chips having nicked someone else's never tastes the same.
Mugshot
Cracking a solo.
I used to have an anterior open bite, which is basically when your front teeth don't meet. Because of this I was unable to bite through things with my incisors, instead I clamped things. Let me assure you that there is no pain, none what so ever, that can compare with a red hot slice of tomato, dragged from between hotter than the sun cheese in a toasted sandwich, flopping down on your bottom lip as you remove the sandwich from your mouth because you've clamped not cut
