I've a 9070 DuraAce Di2 setup on my bestest bike. It's been fine for 18 months but has now developed a very strange and difficult to diagnose intermittent problem. I'm putting this out there to see if anyone has had the same problem and, if it gets fixed, as a record of WTF caused it.
Here's as far as I've got. Apologies for the length but it's all relevant, promise!
Seemingly at random, the entire shifting system shuts down - front and rear derailleurs both dead. Pressing both shifters would normally flash the junction box lights to show battery level, but this also appears dead. Pressing the junction reset button does nothing.
This next bit is where it gets weirder. For most rides, the whole system recovers after between 5-20 minutes. It just all comes back. However, on my last ride I'd removed the D-Fly transmitter and, sure enough, after half an hour everything stops shifting. Except this time it doesn't recover and I have to make it home in a vast gear. With the D-Fly attached, the system comes back up showing adjustment mode on my Garmin, just like this well-known and still open issue https://forums.garmin.com/archive/index.php/t-90282.html.
Also, on the two occasions I've made it back with the system still down, it immediately comes back the moment the junction box is plugged back in to either a charger or a computer. After that point, all is well again, even if the charger cable is immediately removed.
Finally, the D-Fly still operates my Garmin through the hood buttons when the system is down, suggesting that there's still power coming from the battery.
In terms of fixes, I've made sure the battery is charged and removed and reseated all connectors except the internal battery, which is a bugger to get to.
My current money is on a faulty junction box. All the cables looked in good nick, the battery is nowhere near its life and is well protected in the frame. Also, the way the system shuts down and then restarts and the active D-Fly point away from a battery issue, and it's immediate recovery on plugging in wouldn't be typical behaviour for a cable or connector fault.
My TT bike also has Di2, so I'll swap out the junction box from there and see if that makes the problem go away on tomorrow's ride.
Anyone got any other ideas?
