Dish Washer problems. Any advice please?
roley poley
leeds
no problem with the dishwasher in our house our lass just nods in the direction of the sink and off I go^_^
bruce1530
Ayrshire
As someone said above, check the leak tray. There’s usually a plastic tray across the whole base of the dishwasher, with a float switch on it. If water gets into that try, and the float switch triggers, it thinks “hey, I’m leaking”, will not fill any more, and will possibly run the drain pump.
See if there’s any water in the tray. On mine (different model), you can look in the front if you remove the trim panel.
España
@Dave7 Is there an error message or number on the display? If so, try Googling or YouTubing that.
If no message try googling the name of the unit and common words to describe the problem.
It worked for me!
Good luck!
Dave7
Dave7
Cheshire
It worked for me!
Good luck!
Thanks Hobbes. It doesn't have anywhere for an error message to show.
I will try the other suggestion.
Globalti
Have you Googled the product name and the problem? I bet lots of people have had the same problem.
