NickNick
Not sure if this is right bit of the forum for this question? We're in private rented property and for the first time the landlord used British Gas instead of one of his dubious workers to do the gas safety check and they've condemned the cooker (one of the burners goes out when on low setting) and found the boiler to be at risk due to the polarity being reversed. These faults have been there since the day we moved in and have been missed in the previous 6 checks. The prior ones were done in less than 10min, which the BG engineer said would never be long enough to do the testing properly.
The landlord has sent round one of his blokes to do the repairs who is apparently an electrician and a gas/heating engineer (that in itself sends alarm bells ringing to me), he's arranging to get a new cooker which should be fine as its pretty straightforwards.
With regards to the boiler however, he's removed the socket that was coming off the power supply to the boiler and claimed that's fixed it and has taken the warning sign off that BG had put on it.
I know he hasn't actually checked whether his repair has done the trick as he didn't take the cover of the boiler off, which you need to do to check the polarity. I'm not sure if he either doesn't have a clue what he's doing, or he's just trying to do a quick bodge on the cheap to keep the landlord happy and us quiet.
Do any of you know, or know where I can find out, if the landlord has to get another safety check done once the repairs are finished, or if its enough just to do the repairs? Also if he does have to get another safety check done, can he use another company?
My worry is that he will get one of his cowboys out again, who managed to miss these faults for 6 inspections in a row (both faults have been in existence since the day we moved in). I've been searching online for hours, all I can find is that they have to do the necessary repairs, but I can't tell whether he has to get another check done now, or if he can just do the repairs and wait 12months to do another gas safe check.
If he does go down that route, the only thing I can think do is to check myself if the polarity is reversed (a simple multimeter test which I am familiar with) and assuming the fault is still in place, I would have to report them to gas safe for not having done the checks properly.
