Angelfishsolo
A Velocipedian
- Cwmbach, South Wales
Finally some honesty. Now read the OP's replyIt was more the fact that I found your advice to be stupid if you want the actual answer as to what I think.
No they need something flexable, especially as a hard winter is most likely again.So sorry to have offended you. Clearly somebody who rides mainly on roads with a little bit of gentle of road thrown in needs a MTB they don't like. Now it makes perfect sense.
Which isn't most low end hybrids with cheap suspension forks, they ride like turds.
When giving advice it is a good idea to talk to the person seeking it.No they need something flexable, especially as a hard winter is most likely again.
I think that's the wrong way round, isn't it? Suspension (on most bikes) locks in the highest position, which makes the front end taller and will take weight off the hands.sometimes locking suspension alters bike geometry, i.e., throwing more weight onto the hands, might just have been the change in position.
The size of the wheel is a small, possibly irrelevant factor when relating pedal strokes to the amount of ground covered. The main dependency is the gearing and MTBs (again, generalising) have lower gearing than road bikes. However, most people ride at a certain cadence so will select gearing to match.Thus 700c wheels/tyres will cover more ground per pedal stroke
Whilst not agreeing with Zoiders' way of putting things across, I agree with his point about suspension. Cheap suspension forks are pretty nasty to ride and have a limited life span, as well as sucking up pedalling energy and adding weight....the forks tend to be rubbish if they are suspension and they don't take a full size 2" off road tyre either.
Yep I should have said generaly cover more distance per pedal stroke.The size of the wheel is a small, possibly irrelevant factor when relating pedal strokes to the amount of ground covered. The main dependency is the gearing and MTBs (again, generalising) have lower gearing than road bikes. However, most people ride at a certain cadence so will select gearing to match.
700c wheels roll easier because they are generally fitted with higher pressure tyres, but this again relies on the relative specs as you can get high pressure road slicks for 26" wheels and knobblies for a 29er. The main difference, though, IMO, is that the larger 700c wheels will be smoother (if there's no suspension) over bumps, because of the physics of the larger tyre diameter.
... the Myka is a good entry-level spec, IMO. The forks aren't the best, but they are lockable and the only have 80mm travel (enough for your intended use), which is better at that price than the forks which offer 100mm travel. BB5 cable discs are good, as is the drive train, BB etc.I have just seen this what does everyone think, could be a bargain...was in the £460 value brackets so components / forks / brakes shouldnt be too poor??
Looks good. Go for it.I have just see this what does everyone think, could be a bargain...was in the £460 value brackets so components / forks / brakes shouldnt be too poor??
The Voodoos which Cubist links to are lovely bikes. However...
However, the bike is now available at £370 new, with warranty etc
Not at all. If you see a bargain go for it. At the price you are looking at there will be little difference in feel so you might get the one you like the look of the bestshullup you are jsut fed up with this thread now....![]()
