- South Manchester
Also, you might need an extended 'bit holder' if using an electric screwdriver, but I recon a manual screwdriver with interchangeable bits would be OK with an easy out.
looks like an easy out is your best option as the other end is tapered so you aren't getting a bolt in that side
Thanks but what do you mean by an 'easy out'?
Posted a link above. It's like a reverse thread drill bit, it grabs broken screws/bolts and helps undo them. The 'threaded part is hollow on your adjuster, so a suitable sized easy out will fit in the hollow section, grip the sides and undo it
https://www.amazon.co.uk/Extractor-...1659094672-B0F4814PMQ-&hvexpln=0&gad_source=1
The words sufficed for that. The random photo of someone elses bike just confused matters as to the problem.
Remember, if using an electric drill, you might not be able to get it straight enough because of the head tube, so something like this may help
I think using a manual driver would be safer, much less likely to wander or jump, so much less chance of doing damage to the boss.
I was checking what bits and bobs I already have, but not sure if this cable with an "S" on the nipple is a gear cable or a brake cable. If it's gear cable, it's long enough for me to use for this job.
To avoid any confusion, please note this is an actual pic of the cable that I own. It belongs to me. It is mine.
The inner needs to come out to put the new adjuster in in any case.
Does anyone recognise the type of barrel adjuster I need to buy? Thanks
Here's a link to the photo of MY barrel adjuster on MY bike.
Post in thread 'downtube barrel adjuster broken...' https://www.cyclechat.net/threads/downtube-barrel-adjuster-broken.309796/post-7578881
They should all be similarly threaded, Shimano do a number of adjusters such as this one. I'd check the thread pitch and diameter of the one you have at the moment though.
