chris folder
Hi
I have seen few bromptons with customised easy wheels not from brompton they lift bike higher do you think easy wheels would be better bigger?
Is it easier to pedal than the small wheels ?I got the bigger wheels. Not from Brompton. Better for sure
I only just clear my ezey wheels now but will sometimes clip them depending on the shoes i wear at the time ...they are still worth it as i have learned which shoes to avoid when on the brommieIf I put anything bigger on mine then I'd be constantly hitting them with my heels and calves. I occasionally hit the ones on there now.
(edit) mine's a 2002 T3 with a shorter wheel base which may contribute to a heel clip but i dont know for sure
Mine are size 12I miss mine by mm as it is - and that's because I use SPDs so my feet are far enough forward when I pedal. But if I don't clip in on the first go, I'll often hit it quite hard if my foot's not in the correct position.
I have very average sized feet - though my cycling shoes are a UK10 (44) so anyone with bigger feet must struggle.
