KneesUp
I have a number of shelves that I have that self-adhesive LED lighting strip stuff attached to, which is all well and good, but I have it daisy-chained across a few shelves, so if one part gets damaged (as sometimes it does) it knocks out all the other shelves 'downstream' Plus it means that you can't move the shelves (they are adjustable in theory) because there isn't enough slack in the cable.
So I'm going to re-wire then - the idea is to have the power supply feeding a box with several outputs, and each shelf having it's own individual strip, with a small socket on the back / side, so I can then connect each shelf individually to the power box. Hopefully this will solve the issues outlined above.
What I'm not sure on is what connectors to use. The lights run on 12v, and at the moment each 'block' of shelves has a laptop-type power supply connected to a connector block, and then the cabling from each 'run' of shelves connected to that. Obviously if each shelf is to have it's own cable I'm going to be connecting lots of cables to just two wires coming from the power supply - I'm not sure what product I need to do this neatly - or is there no neat way?
I'm also struggling with what plugs/sockets to use on the shelves - I was thinking of using phono ones or 3.5mm headphone because that's something I'm familiar with, but they seem a bit bulky to hide behind the shelves - I'm now thinking bullet connectors, but that is two connections per strip and I want it to be as sleek and foolproof as possible, so any recommendations for connectors would also be much appreciated. CPCs website is kind of overwhelming if you don't really know what you're looking for!
Thanks in advance.
Thanks in advance.
