Deleted member 1258
got up to 180 rpm today, and still felt in control just............
I had my right calf cramp up today descending Purley Chase near Mancetter, I was travelling at around 31mph and spinning at just over 150rpm.
I have to say 150 is just about my comfortable top these days, anything more than that and it starts to feelgot up to 180 rpm today, and still felt in control just............
Ouch! What did you do? Emergency stop?I had my right calf cramp up today descending Purley Chase near Mancetter, I was travelling at around 31mph and spinning at just over 150rpm.
A Surly Fixxer might have worked and been a lot cheaper if you have compatible hubs, but sadly I think production has stopped.I did a 52 mile ride to the coast yesterday single speed 65" on my belt drive bike. I was considering of converting it to belt drive fixed but I really enjoyed the ride yesterday. The only downside was the return 7 mile ascent to my house, in parts it's 13% and I could of done with the forward momentum in those bits.
Not so sure whether just to carry on single speed or spend the £150 to convert....hmmm.
Thirty quid off ebay, but unfortunately you'll still need a Gates fixed sprocket.Not so sure whether just to carry on single speed or spend the £150 to convert....hmmm.
It happened to me a few times during my first winter on fixed. It was painful to say the least! Could feel it for ages afterwards.Thats about all I can do, 150rpm is too fast to just pull my foot out, trouble with it is there rarely any warning, if I get a warning I can drop my heel more at the bottom of the stroke and stretch the calf a bit, which stops the problem, with no warning then a sharp stop and a stretch at the road side, I came back to fixed after a long break about six years ago and I've had this problem when its cold since I came back.
http://www.wiggle.co.uk/surly-fixxer-hub-converter/
Edit: Gone but not forgotten
http://surlybikes.com/blog/post/the_fixxer_is_dead_long_live_the_king
These still add to £80 (the gates screw on sprocket can be bought from inside Europe) and the screw on sprocket is only available as CDX.Thirty quid off ebay, but unfortunately you'll still need a Gates fixed sprocket.
Oddly, I find that fixed stops me getting the quad cramps I occasionally get (and hate).Thats about all I can do, 150rpm is too fast to just pull my foot out, trouble with it is there rarely any warning, if I get a warning I can drop my heel more at the bottom of the stroke and stretch the calf a bit, which stops the problem, with no warning then a sharp stop and a stretch at the road side, I came back to fixed after a long break about six years ago and I've had this problem when its cold since I came back.
What worked for me was
1. Moving my cleats as far back as they would go, which unloads the calf muscle quite a bit. Fortunately my frame design means I still clear the front wheel by a smidgeon (but nobody turns the bars that much at speed anyway).
2. I made a habit of stretching my muscles a lot more when I'm not riding, so it's not so much of a shock when I get on and ride.
3. Warmer clothing for my legs and waterproof/windproof tights on the coldest days.
Quite a few research papers show that stretching actually causes more injuries than stretching prevents, however, warming up properly is shown to prevent injuries.It happened to me a few times during my first winter on fixed. It was painful to say the least! Could feel it for ages afterwards.
In that case you can put your feet wherever you like (assuming you can find toe clips long enough). I haven't tried this method of foot retention, but I'd guess they allow even more freedom of fore-aft foot positioning. It's also worth noting that there are people who advocate a highly rearwards cleat position for reasons of economy and efficiency. Googling for 'mid foot cleat position' will bring up lots more material. For what it's worth, I moved my cleats from max forward to max aft, on my shoes that was a 22mm change, and still a long way from a true mid-foot position. If you go for extra clothing make sure it's not so tight to restrict blood flow. I'll be interested to know if any of this works for you.I'm on clips and straps, but I'm about due a new set of pedals and clips, the pedals I'm using have been on three different bike and are a bit knackered, when I change them I'll have to have a look at moving the feet a bit more forward and see if it helps, I'm wearing long johns under my tights when its sub zero perhaps extending that to wearing them right through the winter might help, thanks for the ideas they've given me more things to try.
Ahhhh, OK. Going chain just destroys the advantage and convenience of not having to oil/clean the belt. If it was mine I'd ride as is for a good while to get some use and enjoyment, then convert to center-track fixed after a year or two.These still add to £80 (the gates screw on sprocket can be bought from inside Europe) and the screw on sprocket is only available as CDX.
So I'd be no better off. I could change to chain drive a bit cheaper, but where's the fun in that?
