Garmin Edge 200 courses not showing
daisyj
Somerset
The courses I uploaded from RWGPS are not showing on my Garmin Edge 200 even though they are showing in the courses folder of the device. I've tried deleting them and then adding them again but no luck so far. They were showing previously. I've also tried just adding back in two in case it was a memory problem but that didn't work either.
Does anyone have any ideas why this might be?
Thanks
Sharky
Kent
Too many rides stored on the Garmin?
Delete previous years some and try again.
Glasgow
Sometimes if my Garmin 200 refuses to play, I delete the lot and start again.
Once I had to do it a few times before it took the route.
Thanks
See Ians post. you need to load them to new files so that the Garmin will convert them, or cast dome magic garmin spell that allows them to show up in courses. dont drag them directly into courses.
damn italics...looks nice though, very pretty.
daisyj
daisyj
Somerset
You are putting then in the new files folder first?
Thank you! No I hadn't, I'd dropped them straight into courses. I've put them in New Files and they're back. Brilliant.
