Garmin Edge mounts
Somehow the rear of my Edge 520 has become worn/chipped, and now does not slot into any 1/4 mount turn with any precision...it sort of sits there but any jolt or bump causes the edge to go flying :ohmy:
Is there any way to either connect the Edge to the bike using anything other than a 1/4 mount turn, or is there any way you can buy/change the rear of the unit? I'm guessing 'no' to both :cry:
I have emailed Garmin, see what they say, but probably "buy a new unit" :huh:
StuAff
Silencing his legs regularly
Portsmouth
You would, sadly be correct. The mount on Edges -all of them, old and new- is moulded part of the back casing, so not replaceable. Garmin will of course sell you a refurb (if you go down that route back up everything you want to transfer first, I lost most of a LeJOG when my dead 705 went back because they just send you another one....). Cheaper option: keep an eye on eBay for a dead 520 (or another model with the same case, if there are any) and use it for parts.
steveindenmark
You can get replacements on e bay for very little money. I have the cheap versions on all my bikes and they are fine.
Bookmarked - as a just in case......
