Giant Peloton SS
From the photo they look like campag callipers, correct?
Good point i never though about that. Yeah as far as I'm aware it was all campag gear that was originally on it. Specialist campag component I take it that's needed?
Fitted my 15t fixed cog. Removed two links and fited my half link! 68gi hopefully it'll be on the road by next week!!
DaveS
Suffolk UK
The campag callipers I have all have a 6mm adjuster, but the callipers are NOT threaded. Instead they have a flat which matches a flat on the adjuster, and slip in freely . Adjustment is made by screwing the wheel adjuster up or down the thread . See pic below. Thus, probably any 6mm adjuster will do if you can file a flat on it and add a m6 nut for adjustment . Maybe you have lever adjusters and just need a cable support, in which case you could just forget the nut on the barrel adjuster. Dedicated campag adjusters would be best though I guess . . . .
I am selling my shimano alfine chain tensioner on ebay if anyone is interested? It was featured further up this thread. Its a good bit of kit, I just no longer need it. Only had it on the bike for like a week.
http://pages.ebay.com/link/?nav=item.view&id=161459342448&alt=web
It's home! Cycled to my parents and back... scary! In the dark, fixed and haven't properly cycled in about 8 years! But I'm back on the road! Onwards and upwards!! :smile:
Any idea why my front brake sounds like a distressed whale when braking? Hahaha
Andrew1971
Northallerton
Front brake squeal's BUT is it good?? and your braking rim is covered with what ever they coated the wheel with. Are they new brake block's?
or brake block toe in/out that's where the rear of brake block is just touching the rim and the front of the brake block 1mm gap. (if memory serve's me right) or get one of these make brake block setting so much easier http://www.amazon.co.uk/Tacx-Brake-...?ie=UTF8&qid=1414087958&sr=8-29&keywords=tacx
Andrew
