ColinJ
Puzzle game procrastinator!
- Todmorden - Yorks/Lancs border
I recently bought a Sundried gilet which I am generally very pleased with but there is one problem with it which has been driving me to distraction. The gilet has small flaps either side of the zip which close over it. They improve the appearance of the garment and must help with wind-proofing it. The problem is that I kept getting the zip slider stuck when the flaps got caught under it. It was a bit tricky taking gilet selfies but this sort of illustrates the problem...
You can't see the slider but you can see that the flaps are covering the teeth of the zip and the material is getting tugged down. That was using my instinctive zipping action, which was to pull the zip up and down pressed against my body.
I couldn't understand how an apparently well-designed garment could be produced without anybody at the company noticing the problem. I thought about it, and wondered whether they were using the zip differently...?
Then it struck me - try pulling the zip away from the body as it was being raised or lowered. I tried that technique...
Eureka! You can clearly see in that photo that the flaps are being opened up, well away from the slider.
I have tried it scores of times now... The old technique jammed the zip about 3 times out of 4. The new technique hasn't jammed the zip at all. It means I can now adjust the gilet one-handed as I am riding along, which I could not do before.
Some of you may find this useful? Let me know below if it does. Or if you are in the 99% of the population who already knew this technique but had never bothered to tell me about it!
