Deleted member 26715
You clearly don'tSo, if I understand you correctly,
I look forward to your correction of my misunderstanding.You clearly don't
And I look forward to you having an input on the thread in handI look forward to your correction of my misunderstanding.
The topics are Guy Martin and Robot Cars, both of which have been known to speed inappropriately - Guy Martin famously getting nearly double the disqualification number of points and two of the Robot Cars in his show spun out due to inappropriate speed because they didn't factor in grip or lack thereof.As previously stated this is well off topic, but without knowing the road, the conditions at the time, it is not possible to answer.
80mph is above the UK speed limit therefore there is no appropriate timeGive any 60mph road and any conditions you like as an example of when you feel it's appropriate and safe to travel at, say, 80mph.
I commented on something you said in this thread. I see from the post above that regardless, it is not permissible to discuss something you said in this thread, because that would be off topic.And I look forward to you having an input on the thread in hand
Top tip
"Top tip" - get with the times. They are now 'life hacks'Top tip
That is something I have been pondering about really bad traffic in London.And of course where humans and robot mix there will be the people that know they can get the robot to give way through reckless action, the same way that people do with other drivers now when they perceive them as inferior.
