Heatwave tyre pressures.
Oldhippy
Cynical idealist
Photo Winner
Never given it a thought or had any issues.
mustang1
London, UK
I take my bike out of the studio and leave it outside for 20 minutes while I sort out my riding kit.
In that time, i figure theres enough time for air pressure from inside the studio to outside the studio to have stabilized in the tyres. I then pump the tyres to 95psi (25mm gp5000) and Im good to go. If the pressure increases due to excessive heat (either by braking or day temperature), I dont think it will make too much difference (no continuous long descents on my rides).
Roadrat77
Roadrat77
Birmingham
I store both mine in the garage which is like a furnace at the moment and when I checked the pressure before a ride on Friday morning it was way up on what it normally is so I deflated all four tyres straight away but I have heard of a few going pop even when stationary which got me thinking.
Big John
Had one blow a couple of days ago in the garage. The wheel belonged to a mate, a carbon rimmed jobby. I put it down to the garage being like a furnace but everywhere is like a furnace at the moment. My sheds are even hotter. I checked the tube and it had split along one of the joins, quite a large hole. Before it blew it was at 80psi. I had one blow on the way home from a TLI bike race. The wheels were in the back of the car. It scared the living c**p out of me 😳
slowmotion
Quite dreadful
lost somewhere
Your tyre pressure will increase by a piddling amount in hot weather. No need to worry.
Lookee here......
View: https://medium.com/@matthew_vdh/how-much-will-my-bike-tyre-pressure-increase-by-on-a-hot-day-9fd76412a951
rogerzilla
Some tyres are perilously close to blowing off when they get to their maximum sidewall pressure (most have far more headroom). Schwalbe Duranos are one of them - they will pop off a rim at around 115psi. Those could be a problem in the heat if you'd put 110psi in during the cool of early morning. Add a bit of brake heat and you're in all sorts of trouble.
T4tomo
When I was cycling in the Alps and summer heat I often found that my tyres had gone from “a bit of give” outside the hotel in the morning to “rock hard+” at the top of a pass. Never had a blow out or any trouble.
Aren't the more likely to be hot at the bottom of a pass, hotter valley temperature and after being heated up by (rim) braking on the descent?
byegad
NE England
My first wife blew a Raleigh Shopper rear tyre off the rim. A long descent where she rode the rear brake all the way down, a bumpy unmade road and the BOOM! sounded like a cannon going off. The tube was in shreds and the sidewall split. I went to help and promptly burnt my fingers on the steel rim. I'd estimate the rim to be well over 150C.
On a similar topic the airline demands that tyres be deflated is a load of fetid dingo kidneys. Give sea level pressure is 14psi, at altitude it is less, but even a vacuum it will only add 14psi to the pressure! Take into account that at high altitude the temperature can be -40C and only a modest reduction below the maximum sidewall pressure should be fine.
Yes I always tell airlines I've let the air out of my tyres - technically I have but only about 5psi. I'd much prefer air in the tyres to protect the rims in transit.
