Crown race was a bastard on mine .... some gluey gunk in the way ....
It was my first crown race installation, it took a hell of a lot more effort than YouTube videos showed. I am glad the forks were not carbon or I would have been down the lbs.
I'm reading reviews on Chain Reaction Cycles and it appears to be a known problem with them. If you look at this review it seems there might be a solution.
The rattle can be fixed by removing the hard plastic piece on the front of the lever and placing a wedge of stiff foam into the space and then replacing the plastic piece. The wedge needs to extend down into the internal part of the brake so that it cannot move out of position. Does not seem to affect the operation at all. Can't say how long this will last, but only takes a few seconds to do.
http://www.chainreactioncycles.com/shimano-tiagra-r400-brake-levers/rp-prod13672
So @Fab Foodie how far have you got with your build?
Ahh great. I normal do better research, but with shimano figured they would not be selling junk. I will have a poke around tomorrow lunchtime. Cheers for the tip (and the wheels).
I do like that Orange!
It'll match my kit!I do like that Orange!
I like that orange colour, I also like the handlebar and brake lever Fab Foodie has used, same arrangement as on my old Pearson.
I'm tempted to polish-up a pair of Tri-bars and add them too ....I like that orange colour, I also like the handlebar and brake lever Fab Foodie has used, same arrangement as on my old Pearson.
There's a small plastic part inside the lever, apparently Shimano fit them to help with assembly of the unit on the production line. It can safely be removed and discarded. I took mine out almost 3 years ago and the constant rattle/buzz was gone
ordering a new sprocket as 44x16 seems a little under geared for me,
So a bit of an update - I have commuted a bit (tiny distance) and also messed around doing some local geocaches with the kids, but this weekend finally went out for a shakedown. So what did I learn?
1.) It is not light - 11.1 KG without bottle cage and saddle pack.
2.) Despite measuring up my other bikes I had to make a surprising amount of small adjustments to the Holdsworth whilst out.
3.) Bunnyhopping at speed (cattle grid) is tricky on fixed
4.) I do not have the souplesse to handle 166 RPM without my bum bouncing around all over the place like a porn movie on fast forward.
5.) I am a little undergeared 44 X 16 (74 gear inches?) - I think it is flat enough around here to handle something a little higher, although a few climbs were a bit of a grind.
6.) I love the silence whilst riding
6.) Fixed is fun, although I still need to remember to concentrate whilst braking, indicating and trying to maneuver around traffic all at the same time.
