Profpointy
Fair point. It'll be the 3/4inch standard size then.
I very much doubt it, but it is conceivable
I'd go for the first one I listed in my previous post, as that will fit both 3/4 and 1/2 inch, having the insert for the latter.
Er, no it isn't, that's 3/4" BSP:some pictures of mine, which is a 1/2" BSP. As you can see the external diameter is a touch over an inch
Here's the BSP page from my Machinery's Handbook, 1/2" BSP is 0.825" OD, 3/4" BSP is 1.041" OD, a ruler will tell you which one you need:can we have an agreement regarding which size I should buy
mine measured 23mm across the bottom
Assuming that's across the outside of a male thread, that might be 5/8" BSP, in which case I'd give up and fit a new tap. You could try your washing machine hose on it, if that fits it's 3/4" BSP.
I doubt it's 5/8 BSP on a water tap as that would be very unusual.
Yes, it doesn't sound very likely to me either. I wondered if he was measuring the inside diameter of the female thread instead, but 23mm still doesn't match either of the standard sizes. There are some non-standard threads about of course, I recall years ago one of the compression fittings manufacturers was using a non-standard thread instead of 1/2" BSP. Might have been Conex IIRC.
