Deleted member 20519
BB shell measures 71.25mm. Seatpost diameter was 25.45mm and the handlebar diameter is 24.95mm.
Did you remember that it undoes in the opposite direction to the first one?Got itI managed to remove one of the cups and then the spindle but the other cup seems to be stuck tight.
Thanks for all the info guys. Is there going to be a problem using quick release with horizontal dropouts?
Nope, just use an internal cam skewer as shown below, and do them up nice and tight.
Would these ones be suitable? http://www.amazon.co.uk/dp/B000B7J7JM/ref=asc_df_B000B7J7JM13561454?smid=A1MVOUW2EB3HKK
Is there any problem with having a space between the two nuts?
I don't know if you can make this out in the picture but the upper nut can't be tightened any further, it's just stopping once it reaches the top of the steerer.
In that case the headset is missing some spacers (similar to threadless headset spacers, but only 1") between the two nuts which stops the upper nut from running out of thread.
