Deleted member 1258
Went out for a first ride on the bike, planning on heading to the coast and back for a nice flat 40 miler.....
Got about two miles from home and chain snapped
Wasn't even putting in *that* much power when it happend, though it was up a hill. Is this more common with fixed gear than with freewheel bikes? Is it perhaps a sign that I need to get the chain line better than it currently is perhaps? It's the only chain I've ever broken, it was quite a shock when it went!
View attachment 356816 View attachment 356817
I was planning on ordering some new tyres for the bike anyway so I guess I'll add a new chain to that order.
Unfortunately that drive side crank does also rub against the chain stay under power. Can't decide whether to crimp the chain stay a little or to try and find a new axle... the difficulty there will be that the seller said he couldn't shift the BB fixed cup (a problem I've encountered on a few other bikes).
That looks like a simple chain failure, looking at your pictures your chainline looks OK. I think you need a longer bottom bracket axle though, trouble is a longer axle will mess up your chain line and you'll have to sort that out once the longer axle is fitted.
https://www.sjscycles.co.uk/cottered-traditional-axle/
http://www.starcyclespares.co.uk/no...ed-bottom-bracket-cycle-crank-axle-2730-p.asp
