Andrew1971
- Northallerton
@ChrisEyles What coloured handle bar tape are you going for.
Andrew
Andrew
Managed a quick ten miler after work today and the saddle's not half bad. The skirt is a tiny bit wide with a bit more thigh rub than on my B17, and I think it needs a little bit of tensioning up as it's got a lot more give than the B17 (I guess this may pull the skirt in a bit at the same time). I've also seen DIY methods to turn a B17 style saddle into a more Swallow/Swift shaped saddle, which I'm also tempted by, but probably too scared of messing up to try!
The bar tape is very comfy and much nicer than the old stuff which was more like textured electrical tape.
It's certainly a head turner, I think I've had more comments about this bike while I've been riding it than any other road bike (my sit-up-and-beg 1950s Raleigh still wins hands down on that count though!). It's definitely the bike I can't wait to ride again at the moment
Thanks a lot to all who offered helpful advice along the way - as always, it's much appreciated!
Can you get chain tugs for forward facing drop outs? I can't remember seeing these, but if so that would be probably be worth doing.
I'm not sure why the chain broke either. No broken plate this time, just one of the rivets missing. Guess there must have been some serious sideways bending forces where the chain tried to climb the teeth of the rear sprocket during chain derailment.
Thinking about it, the easiest way to straighten out the chain ring is probably to use a flat surface like you say, and to put the high spots over the edge of the work bench and bend them down with a big adjustable spanner. Not sure the hammer would do the job on a one piece crank/chainring.
