So I've decided that whilst I'm already mid-DIY adventure with the front extension it would be a great idea to break away for a week or so and insulate the garage
In the last few years I've made some improvements by replacing the main garage door with an insulated electric roller-shutter and the personnel door with a nice insulated composite door but there's no getting away from the fact it's a single skin stand-alone garage. If it's freezing outside it's freezing inside
Since I've made the space much more usable recently it seems daft not to finish it off with some insulation so I can use it comfortably year-round.
To that end I've ordered lots of insulation
Plan is:
- Empty the roof of a decades worth of crap
- Remove the haphazard boards that the previous owner balanced across the joists and screw down some proper boards for storage, braced if needed
- Insulate the rafters with 50mm celotex leaving a vent space above
- once the roof is done I'll move all the crap I haven't discarded back in to the roof and tear out the cupboards and benches to expose all the walls
- batten the walls with dpc between batten and brickwork, then 40mm of taped celotex with foil vapour barrier, then 15mm OSB screwed through to the battens
- Paint OSB
- Re-run the electrics in surface conduit
- Fit some sort of smart heater so I can preheat the room remotely when needed to save heating it continuously
Then I need to think about the best use of the new space and what to replace the benches with, the stuff in there at the moment was all built in by the previous owner and, unlike the roof boards, is absolutely solid - I imagine it'll be fun trying to remove it
I've read a few articles and know the insulation thickness I'm using is below that required of the current regs but really all I'm hoping to do is stop it being freezing cold - I could see my breath in there earlier
I'll continue to use the turbo trainer in there, and I also run 3D printers in there which don't like the cold at all. I want to avoid damp which is probably my greatest concern as I don't really want the roof timbers rotting through at any point
To this end I'll be extra careful to tape all the insulation joins and try to avoid cold spots, but some will be inevitable due to the construction of the roof timbers. Would be good to hear others thoughts on this so if you have any experience, tips, advice, please let me know
Since I've made the space much more usable recently it seems daft not to finish it off with some insulation so I can use it comfortably year-round.To that end I've ordered lots of insulation
Plan is:- Empty the roof of a decades worth of crap
- Paint OSB
