I fitted the ladder this evening. I've also finished mulling, and decided to reinforce the roof with some extra timbers.
Heres the ladder, nicely stowed away 😊
Whilst on the turbo earlier I kept looking around at the options and kept coming back to this block pier...
It's exactly halfway down the garage, but only on one side. I figured it really wouldn't take much effort to build a matching pier opposite it as I have blocks spare, so I'll bolt some wall starters to the bricks and stack some blocks up at some point
I've then got some 50x150 timber left over from building the new roof, so I'll put a couple of lengths of that across between the two piers, halving the span of the existing trusses. That should strengthen it up a bit on it's own, but then I've also ordered some lengths of 70x45 (the existing truss chords are 70x30) to put an extra length in between each truss, halving the spacing from 620 to 310 centres. It's still not perfect, but it'll be a lot better than just piling things on the trusses and as I've said before, I don't intend to store much up there anyway
This causes some logistical problems as it means I need to rip the cupboards and bench out before I really wanted to in order to build the new pier, unless I can sling all the timber up first and build the pier up under it at the end
I'll have to think about it a bit more
