dodd82
Sorry for the delay, it's been a busy week.
Not at all, I just wanted to be sure of what you are saying, which is that it is valid for someone to interpret 220 degrees as a right turn, and accordingly signal right until the turn, and it is also valid to interpret it as being straight on and so give no signal until the left indication at the exit. Two different behaviours from the same situation both of which you say are correct. You, therefore, should have no reason to criticise either driver for their indication if you interprete the roundabout differently.
What you have still failed to grasp is the value of a right indication on roundabouts, even if it doesn't match your interpretation of the highway code. I can give an example, which is not unique, of a local roundabout where there have been several accidents caused by vehicles leaving the roundabout from the right hand lane into the right lane of the exit, cutting across a vehicle in the left lane that was leaving the roundabout by the following exit. I'm having to guess here as I haven't been able to ask the offending drivers, but I suspect that driver 1 thought that driver 2 was going to leave into lane 1 of the same exit. If driver 2 had been signalling right as he approached exit 1 the accident probably wouldn't happen. So the question for you in this circumstance is: which is better, making a signal that is not recommended by the highway code or having an accident?
Another example is on that same roundabout, and between the same 2 exits many drivers indicate left before exit 1 but leave at exit 2. There are some drivers entering from exit 1 that might assume that the driver on the roundabout is precisely following the signalling recommendation of the highway code and so will believe that they can safely enter the roundabout in front of the car that is exitting. The question for you here is would it be safer for the driver on the roundabout to be indicating right prior to exit 1, or would this be stupid as you have previously stated.
I accept what you said previously about roads such as the A1 in the rush hour where 2 lanes of traffic are leaving a roundabout on a major route, and in cases like that it wouldn't be appropriate for all traffic to squeeze into the left lane to exit.
No, not really, A lot of my driving habits were provided when I went on a defensive driving course many years ago. The instructors were experienced advanced drivers and ex-police drivers, so I value their advice more than yours as I suspect you are inexperienced by comparison.
Oh dear - we've got ourselves a trier.
Face it, you're wrong. Your example of a one lane roundabout is your attempt to justify your original stance, as is your bizarre decision to argue that you shouldn't exit a roundabout from the right hand lane.
The discussion was about a two lane roundabout, with a driver in the left lane signalling right but intending to continue straight.
You should not be signalling right.
That's not an interpretation of the highway code - that's a fact.
Poor driving - such as drivers that indicate left too early, or don't indicate left at all before leaving, does not change that fact. Several people have given you examples as to why the right signal is confusing and therefore dangerous.
You're obviously someone who is never wrong, so congratulations with that.
Now, if you wish to debate such points as whether you should leave a roundabout in the right lane, then that's a separate subject matter. You're wrong about that too, but it's not helpful to cloud the original discussion with it.
