Is there such a beast as a folding Road bike?
NoelMc
Regular
Folding roadie ? Sure.
First get rid of the hang-up that small wheels are slower/ inferior. (lighter, lower centre of gravity, less rotating mass).
Small wheels have smaller footprint. Skateboard wheels are capable of 100k/hr.
Tyres! The most important bit. Get the narrowest highest pressure tyre that fits your rim. I have Schwalabe 115psi 1.10in.
Make yourself comfortable if not racing. I dont use clip ins anymore, just nice wide comfy BMX.
Enjoy the ride- it is different.
My folding roadie is a Birdy. It folds at the ends, stem & seat post.
The unique thing is that where the wheels fold, there are nice little elastomer suspension blocks.
Yep a dual- suspension roadie.
It looks a bit weird at first till u get used to it.
https://www.google.com.au/search?q=birdy bikes&client=firefox-a&hs=yBY&rls=org.mozilla:en-US:ohmy:fficial&tbm=isch&tbo=u&source=univ&sa=X&ei=3s-RUq2FLIKBiQf_t4DwAg&ved=0CDYQsAQ&biw=1366&bih=613
Happy adventuring, Twiz
natsharm
I've fitted drops + 700c wheels to a Dahon Jack/Espresso frame - No problems. I'm using this in London on sunny days...
The nice thing about this frame is that all the fitting points are standard, only the folding hinge is specific to Dahon... so minimal risk in my opinion for spares. My other bike is a Dahon Jack which I've used for over a year now, so I'm used to the frame and size.
Not sure if these pic links will work (here goes):
http://www.flickr.com/photos/77981342@N02/6999778160/
6999778160
http://www.flickr.com/photos/77981342@N02/7145844537/in/photostream/
photostream
Hi
I'm just about to buy components and build up a dahon/road bike like yours and would be very interested in the parts that you needed to convert it. I'm a first timer at building a bike but it should be fun if I can avoid novice pitfalls.
Do you still enjoy the Dahon bike you built?
natsharm
Just thought I'd post a couple of pics of the folding roadie that I've just converted from a dahon jack d7. Only the frame, saddle and post were kept from the original dahon, everything else has been replaced. Was doing this on a budget.....sora groupset has replaced the old sram bits. Really happy with this......been using it for my commute on the train for a week now and it rides great......a slightly different feel to my standard roadie but still smooth and quick. Many thanks to Schocca for the help and advice on parts.....much appreciated! Just need to get one of the small fixed dahon stands to protect the chainrings when it's folded and it'll be complete.
I'm thinking about converting a Dahon as well. Are you still happy with you folding road bike? Do you have a list of parts that you used and any other suggestions that can make my build easier. I'm new to all this but looking forward to the learning curve.
Nat
Hacienda71
Don't think either of them have been on the forum since Jan. You might be better sending them a PM which may send them an email alert.
RecordAceFromNew
Swinging Member
West London
The key things to watch out for, include:
1) If the folder has flat bars with mtb/trekking rather than road components then the front mech and brakes are likely incompatible with drop bar sti, rear mech compatibility depends on #speed and make
2) If you want to be a purist and change 26" wheels to road 700c then you will also have to consider brake reach for rim brakes as well as rear dropout distance - flat bars are usually 135mm and road 130mm
3) the full size dahon folders need top pull front mech
4) putting drop bars on a flat bar bike will increase reach quite significantly - fit can become an issue if it was good before, although playing with stem length and angle can help
5) If you change the forks it affects brake choice, steering can be affected if you don't ensure the new forks' axle to crown distance is similar, and steerer length and diameter etc. become relevant
None of the above is insurmountable, just need a bit of care in picking components, but exactly what you need is of course dependent on the starting point as well as the end point.
I took a different route, changing everything on my Jack except frame and forks to make it lighter and slicker while robust, keeping the bars flat, the wheels 26", and Nx1.
schocca
Apologies for not checking this thread for a while - If you want to build your own Dahon Jack/Espresso road bike conversion, I have made a simple spreadsheet with the parts you may need...
https://dl.dropboxusercontent.com/u/94008535/Jack - going road (and black - lots of black).xls
This is mainly detailing Sora parts. (I initially used Tiagra 2012 10 speed on mine). The primary difference between a regular road bike group set is this:
1) Front D is a top pull device (a Shimano Cyclocross 2 ring FD can be used here)
I'm still riding mine and enjoying every minute - I have upgraded several components to Ultegra + Ultegra C24 wheelset - The wheel set massively improved the ride performance (you get what you pay for). Current mileage is 3500+ and should be adding another 1000 miles this year.
Fife
The A Pacific Reach is not available in the UK any more.
But this may be an alternative if you OK with smaller wheels.
https://www.kickstarter.com/projects/1844575826/vello-bike
One of the presenters of the tour de france (Phil Liggett) has / had a Pacific Reach.
Seems He had a Bike Friday too...
http://www.galfromdownunder.com/references/
All very similar bikes!!
One of the problems of small wheels is gearing, you need a whopping front sprocket, this can be over come using the over drive of a hub gear - so something like a dual drive https://www.bikefriday.com/userfiles/DualDriveManual.pdf
Also to echo the other comments, you need a good set of tyres and tubes, high pressure with flexible side walls. It was the horrible tyres that killed the step though bikes of the 70s.
......with the right tyres a Raleigh 20 can be a great wolf in sheep clothing!! :-)
https://hadland.wordpress.com/2012/06/24/raleigh-twenty-r20/
Cheers
CS
Hi everyone, I started working on converting a Dahon Espresso (Pininfarina) to a road bike. I bought a second-hand Shimano FC-4550 (Sora/Tiagra around 2011) 175mm crankset and a Shimano Tiagra BB-RS501 68mm bottom bracket. The problem is that the right crank is max 1mm away from the frame and the left crank is already touching the frame. Can anyone give me some advice and experience with this? I'm not very familiar with Hollowtech bottom brackets, I don't know if there are any spacers that can be put in without negatively affecting the attachment of the left crank? The chainring is also close to the frame, but unlike the cranks, it's not completely touchable.
I lide Schocca excelent road conversion https://www.flickr.com/photos/77981342@N02/with/6999786706/, but unfortunately he doesn't come here anymore. I know that he probably had a very similar crank there, but I don't know why it doesn't work for me.
Thanks a lot.
TheDoctor
The TerrorVortex
Hello and :welcome:
This thread was last active over a decade ago, so you might not get any answers.
Spacers for these cranks are available - they go between the bearing cups and the frame. That should get you some clearance, although I'm not an expert on such matters! Personally, I'd use the rather old-skool square taper cranks, as you can get various widths of bottom bracket spindle, and they're more forgiving of general bodgery. HTH.
