Hi All,
Just joined and new to the site and am hoping you can help me out.
I am not an actual owner but my bother has been for many years. He has been using several older model PowaBykes to get around due to mobility problems.
As an engineer, I have been looking after and maintaining them for him, having gained a wealth of information from the PowaByke website.
Recently an opportunity arose to purchase second hand something quite different for my brother. This is, I believe called a Wuxing H T-268. It is modelled more to look like petrol powered moped.
Of course I have quickly discovered there is a huge difference between the powabyke and this one and feel I need a little help. My brother has found it is slower and does not have the same range as his old bike even though this has new batteries in it.
I have looked on line but can't find an actual website for the bike. I did find a couple of links to suppliers and have emailed them but had no answers.
I am hoping someone here has some expert knowledge on this bike. If you do, please help !
Specifically I was initially wondering the following:-
+ What should the maximum speed be and can it be adjusted ? I know the weight it is carrying will have a bearing on this.
+ What should the range be like in miles ? Like above I know the weight makes a difference.
+ The batteries are lead acid. As an engineer I would say these need to be fully charged and discharged every time but I have read on some site they should be topped up as often as possible. Is that true?
+ Does anyone have or know where I could source a user manual and a service / technical manual like on the PowaByke website?
I am also having some specific issue with the batteries at the moment in that the charge does not last very long at all. In fact only around 3 to 4 miles.
I have done some tests and the charger seems fine putting out 42 volts when measured off load and 39 to 40 across the batteries when plugged in. There are three in total.
Having measured the batteries it looks like we have a bad one as two sit at 12.8 volts while one is at 10.4
So it looks like I need to replace just the one battery. I was thinking this because the batteries were all changed just over 6 month ago by the previous owner for new ones but it was then put into storage. It was not charged during this time and the batteries were left connected. I think therefore the charge has dropped so low it has damaged this one battery.
Do you think this will be ok and also do you think the batteries fitted are the best ones for the job.They are 12V 12Ah as shown in the attached images.
Thank you so much in advance and apologies for all the questions.
Your grateful new member
Jonathan.
Jonathan.
