Deleted member 26715
Grabs spanner tightens bolt, many years later has it come loose, nope, must have been the right torque then.
Your fault for tightening too tight then, can't have it all ways.Grabs spanner tightens bolts ..notice cracks many weeks / months later
Can I have a new bike under the lifetime guarantee ??
Each to there own choice to abide by manufacturers tried and tested R/D procedures
Hands up who uses titanium bolts; and why? ('CycleChat' cycles not b****y cars or motorbikes.)
Mix bikes made from aluminium ...steel ...carbonWhat bike are you riding as your favourite, @Lookrider ? I'll be guessing it's not metal. Have you worked on a metal bike?
I bought a torque wrench some years ago. Read the instructions carefully. Set it to the recommended torque for stem bolts. Started doing them up. Thinks "Hmmm this is tight. Tighter than I normally do it. Still, it's a torque wrench, so I must have been doing it wrong all this time" ... PING! The bolt sheared.
Doubtless I was doing it wrong, but nonetheless I've never used it as a torque wrench since. It is a nice ratchet wrench though.
No, I don't own a carbon bike.
.they to are engineers who test do tests and researching your bike was broke as a shop tightened something by feel
You would not get a replacement from the manufactures guarantee
Lord forbid a fatality again you would not stand up in court for doing torque by hand
.Loctite 222.Hope you used threadlock on those chainring bolts.
I use them very dogmatically when rebuilding assemblies subjected to +900 MPa.A torque wrench used dogmatically can be worse than a sympathetically used spanner. It’s like my dad used to tell me about using a calculator - you have to at least have some idea what answer you are expecting or what order of magnitude; same with a torque wrench - you have to have an idea what feels ok. I’ll use one for torque-critical components but more often than not will go by feel, on any and all frame or component materials. It has been decades since I last sheared a bolt (the last I can remember was a thermostat housing bolt on a 1977 Mini, sheared in 1991).
That’s what I might describe as a “torque-critical component”. I’d wager you’re doing it with some knowledge and experience too.I use them very dogmatically when rebuilding assemblies subjected to +900 MPa.
