mickle
innit
- 53.933606, -1.076131
Now with spangly chain. I test rode it earlier. Its very slightly too long in the reach. Easy fix.
Personally I'd want a tourer to take 38s unless travelling light.
You don't need braze ons.
You can use these:
http://www.wiggle.co.uk/tubus-lm-1-mounting-set-for-forks-wo-eyelets/?lang=en&curr=GBP&dest=1&sku=5360212548&kpid=5360212548&utm_source=google&utm_term&utm_campaign=UK_PLA_Accessories&utm_medium=base&utm_content=mckv|sdriEfelS_dc|mcrid|67090793102|mkw||mmt||mrd|5360212548uk|mslid||&mkwid=sdriEfelS_dc&pcrid=67090793102&prd=5360212548uk&pgrid=17507339822&ptaid=pla-296624071193
though not of course with a carbon fork![]()
Another rexponse to this so true post. I was in a nice local bike shop around a year ago on a bit of 90s steel and a guy in the shop said he'd recently had a mail/fb post from a mate somewhere in the middle of the stans on the very same bike. I also remember a young non cycling italian of my acquaintance (italians can be so "bella figura") breathlessly telling me about someone he knew who had been for a ride around europe and that he had "a really expensive bike". I well remember saying that you don't need an expensive one, just a good one.A 90s MTB in steel is a very good starting point for this type of project. I reckon you could get around the world for way, way (and indeed way) less than Thorn et al would charge - like perhaps a fifth, maybe less.
If you have 'issues' with the rear brake bridge there is an easy 'work around to avoid drilling it for a sleeve nut, Just use a front caliper on the rear, the only difference is a longer bolt and that's long enough to use a standard Nylock nut. As for drilling the back of the fork that's easy, I've done it to a couple of my bikes.I had a play with the ridgeback last night, took some 700 wheels from my daughters Ridgeback voyager (I think), they are shod with 42mm tyres. the upshot is that if I buy similar and clad them with 38mm tyres, the thing works. only issue now is getting brakes to fit. long drop callipers will fit (and work correctly with the brifters) but I am open to other ideas. the only other issue is the threaded stud on the callipers not being long enough to protrude through the back of the steerer tube/fork mounting holes but can be overcame by drilling out the rear hole to accept the tubular nut.
I really want to give the ridgeback another lease of life tbh - its served me well.
I'm not sure what the problem with fitting 26" wheels as intended is?I had a play with the ridgeback last night, took some 700 wheels from my daughters Ridgeback voyager (I think), they are shod with 42mm tyres. the upshot is that if I buy similar and clad them with 38mm tyres, the thing works. only issue now is getting brakes to fit. long drop callipers will fit (and work correctly with the brifters) but I am open to other ideas. the only other issue is the threaded stud on the callipers not being long enough to protrude through the back of the steerer tube/fork mounting holes but can be overcame by drilling out the rear hole to accept the tubular nut.
I always wonder how these companies sell enough Expedition bikes to make it worthwhile? I mean how many people actually need an Expedition bike? Most people have jobs and of those retired, I'm sure not that many of them go off on solo Expeditions.
I'm not clear on the physics of why you think bigger wheels are faster though? 26" are stronger, so you spend less time fiddling with spokes (in theory) so more time moving, and you can gear the bike any way you like.just wanting a slightly quicker bike to tour on.
I wont be getting rid of the old wheels, although the front is original, as they are great for canal/river/gravel and rough stuff riding
The best reason!![]()
