Miles or Km
It's interesting in a weird sort of way that this topic is still being discussed some 40 years after the UK Metrication Board was wound down*.
Quoting Wikipedia...
The following year the Metrication Board was wound up*, one of the 457 Quangos that were wound up in the "Quango bonfire" of 1979–81.[12]
*Wound up/wound down? A topic for another thread^_^
anothersam
SMIDSMe
Far East Sussex
That's the Cleveland in Ohio, which became the first US state to post distance signs in metric in 1973. Haven't checked lately, but I don't believe they've gone too far since then.
(Some graffiti artist added the furlongs...)
Ajax Bay
East Devon
I guess the convention is to write abbreviated measurements in lower case.... m2, cm2, lb/ft, km, 21c, 21f, etc.
As far as metric/SI units are concerned, m, s, kg are all correctly lower case, and of course m (1/1000th), c (1/100th) and k (1000 times) are in common use, though (in common use for information and power generation metrics) M and G are the first of several '10 to the power of' prefixes and all these from 6 onwards are capitals . In addition abbreviated measurements of many derived units are capitals eg: A current, V voltage, W power, Hz frequency, N force, J energy.
I'd advocate the BBC style which holds that "There is no acceptable abbreviation for 'miles'". "mi" is just useless and "m" is already taken as a distance measure abbreviation, but for clarity/brevity some UK road signs do use "m".
avecReynolds531
Small Island
I don't mind both but somehow (no idea why) find it easier to relate distance & effort in km.
I love the kilometre markers I found on French climbs - showing the altitude, distance to summit and next kilometre average gradient (not great when you see 11%). Maybe that's the reason after all...
Baldy
ALVA
Isn't an upper case K Kelvin, lower case is kilo. Not sure what an upper case M is, mass maybe as in E= MC squared. When using scientific abbreviations upper/lower case does matter.
C R
Worcester
Upper case M is mega, mass is usually lower case m, usually context tells you if m stands for mass or metres in a particular case.
Ajax Bay
East Devon
Yesbut (and early credit to @C R ). 'K' is for degrees Kelvin (one of the 7 SI units, as opposed to derived ones) and 'k' is widely used and understood: not much chance of confusion even with no context as 'k' is a prefix and must be followed by the unit (eg 'g' or 'm'). M (capital and = 10^6) is only a prefix; and the dimension symbol (not unit) for 'mass'. @Baldy maybe you were thinking of Mariah Carey's E=MC^2 album.
  • Like
Reactions: C R
Gravity Aided
Land of Lincoln
Most American cyclists seem to have the metric system quite well figured out.
We are working at bringing the rest up to speed.
