Profpointy
Seriously i think the OP with Phd in Engineering is not going to take that advice !
Why not? The advice seems sound to
me and a PhD engineer would be able to confirm that it's sound
Same here dafty but I’d never suggest to someone on the internet to go and take that risk ?! That’s just stupid !!You lot crack me up. There is nothing unsafe with sticking an insulated screwdriver into an Earth pin on a wall socket. You could easily do the same for each of the pins and be totally safe.
If you know what you're doing.
Ive got over 30 years of electrical/ electronic trade experience. Everyone is so timid of trying to sort problems out for themselves these days.
Like I said if you dont have the confidence get someone who has
Im sorry its neither stupid ir risky. Coupled with the fact this person has a high level of 'engineering' qualifications. He can surely understand the simple process with insulated tools.Same here dafty but I’d never suggest to someone on the internet to go and take that risk ?! That’s just stupid !!
I highlighted insulated because its key to ensure safety
I don't have the right (i.e. insulated) tools. Ergo I'm not going to try.
My area of expertise is in strength of materials and vehicle impact. And I'm female, btw...
i worry sometimes I really do ?
How would you measure the voltage then
Apologies not knowing you're a girly. . Its fine if you dont possess the tools.I don't have the right (i.e. insulated) tools. Ergo I'm not going to try.
It reminds me, in my day when diagnosing microwave oven problems. I would regularly tap into the magnatrons HV circuit to test current draw whilst running the oven and also HV output. AlI done using an analogue AVO meter. Fluke digital meters back then weren't able to measure the peak HVHow would you measure the voltage then ?
I know do you
However I wouldn’t be sticking screwdrivers in socket holes to do it !!! You know there’s a reason for all these safety features !!
But it could have been short/open circuit rectifier or capacitor gone open circuit or low capacitance.Depending on the fault , you don’t need to do any testing ?! My rather spendy built in microwave stopped heating, did everything bar heat the food ! Easy fault to diagnose ,no need to measure anything , magnetron goosed ! New one bought and hey presto hot food once more .
Seriously? You’re advising the OP, who in her first post said “I’m out of my depth when it comes to electrics” to stick multi-meter prongs into a live socket! Apart from the possible contact with live parts, someone unfamiliar with the kit might have the meter set to read current instead of voltage. The result would be disastrous.Im sorry its neither stupid ir risky. Coupled with the fact this person has a high level of 'engineering' qualifications. He can surely understand the simple process with insulated tools.
