simon the viking
I would like to refer my learned friend to the previous answer
https://www.cyclechat.net/threads/moving-a-ground-anchor.241668/#post-5418750
Yep.. At least when it goes back in it will be at back of garage... Not at front...
Just going to add this to my Watched Threads...
...What? You mean it's all over? Aw crap!
Is it worth sticking around while the new holes are drilled?![]()
.. Just wished id spotted the holes 2 years ago..... I assume they were part of the fixings of the walls that weren't usedIs the ground strong enough?Err... Sorry on closer inspection I found some pre drilled holes in the prefab concrete walls roughly where i wanted it.. And I'd bought a few different diameter rawl bolts in preperation... I had a couple the right size... Araladite on the rawl and on the thread of the bolt...
So all sorted... With big blob of p38 on bolt heads to prevent removal with socket...
Sorry no entertainment there folks.. Just wished id spotted the holes 2 years ago..... I assume they were part of the fixings of the walls that weren't used
Its the concrete wall. Hopefully if anybody tries to steal they'll pull the garage down and save me a jobIs the ground strong enough?
at the ready.
... I had to google the image... Should of realised Mrs V likes them and has one or 2 of their albums....Someone's just worked out the post before the tool update.
Nine hours later.
I'm thinking.... place a small cold chisel between concrete and anchor and then smacking it hard with a small sledge hammer...
Because in theory all I have to do is strip the thread of the bolt in the nut bit of the rawl and by forcing the bolt upward may do this...
Its that easy...![]()
You really should have before postingNot read all the thread as I have a life apparently...
