l4dva
- Sunny Brum!
... So I’ve bitten the built and brought a specialized langster, second hand off gum tree it was missing a front wheel but it was in pretty good shape and relatively cheap so I went for it! Pictures to come soon...
I've done two commutes on it so far and I’m surprised at how easy it is... after the first commute (10.5 miles each way) my legs/knees felt tired but I think that was down to the seat not being at the right height and the excessive amounts of spinning that I’m not used to normally (I try to grind through higher gears usually). Most of my commute is flat, have quite a few up/down hill sections for about half it but no major big hills. So I can spin comfortably at 18 mph is on flats probably at a cadence too high for my liking but it can be done, when I get up to 20+ mph I spin out and my legs cant keep up.
I really wasn’t expecting to be able to spin up to 18mph on a single speed bike its quite impressive, the hills actually seem easier because your already in a low gear. Not sure if all of this is just excitement of being on a new bike and im trying harder, but it feels easy to ride which I wasn’t expecting.
Do you reckon it’s worth changing my gearing? I have the standard set up on a 2010 langster, I think its 42 tooth at the front and 16 at the back.. I think. What would be best do you reckon bigger front or smaller back? I’m going to carry on as it is for a little while to see if I start to struggle with current gearing but because I spin out quite a lot I’m thinking I should change?!
Few other bits I’ve noticed, when I changed the pedals to SPD's one side crank had half the tread missing for the pedal to grip on to, I’ve been using it but the pedal has only got half the usual amount of thread to grip on to.... is this safe? If I’m changing gearing would it be worth changing the whole chain set because of this?
And finally brakes... the previous owner used it fixed so he took the back brake off. I've changed the pads on the front and the bike stops nicely now after i set that brake up properly but i want to reinstall the rear brake, he gave the original brakes and levers that he removed. The lever is pretty much un-usable though as it is missing the pin that holds the lever on to the housing, a part which cannot be replaced or purchased I’ve been told by an LBS. so I'm thinking of taking this opportunity to change the bars and the brake levers to bull horns as it currently feels like I need extra length in the stem, so I’m thinking bull horns will help stretch out my position a little. Dose anyone know what type of bull horns, clamp size would fit the langster and then the type of levers id need as well.... want to keep it as cheap as possible so any recommendations would be appreciated.
Thanks
L4dva!
Thanks
L4dva!
