I've been done around 60 miles on my week old Bianchi Via Nirone, and I think it needs some minor adjustments. I'm sure I can work out what to do but thought I'd run it past you guys first.
1) A couple of times I've managed to up-shift the front chainwheel beyond the outer gear causing the chain to come off. Presumably I can adjust the end-stop bolt on the front deurailleur (sp?) for this? (Tiagra shifters/compact chainset)
2) It's developed a little bit of play in the headset, where the handlebar stem goes into the frame. If I brake using the front brakes it makes a slight knock noise. On closer examination, whilst holding the front brake with one hand and holding the base of the stem and frame with the other, pushing the bike against the brake you can feel a tiny bit of movement at the base of the stem in relation to the frame, only a tiny bit tho. Do I just tighten this up via the socket headed bolt going down thru the top?
3) I'm thinking of raising the handlebars slightly, it looks like there are a number of shims/spacers on there at present so I guess I would need to acquire some more of these and fit accordingly. Any pointers on where I could get some?
Many thanks
Chris
Many thanks
Chris
